I continued twisting my body in the tail section of the fuselage to install adel clamps and route the coax cable for the VOR/ILS/LOC antenna.
After getting it through to the rear baggage area I was able to route it through the conduit on the right side then through the center spar section and up the right gear tower to the back of the GNS 650 where it will be attached.
A couple more wires to weave to the tail section and I will be done crawling in the tube for wiring!
