I began by installing a nylon wire tie clip to the right side of the forward support that runs between the gear towers. I then used a wire tie to get the wires temporarily held in position. I got a bag of junky wire ties that are "expendable" for the cause....use'em, cut'em, throw'em away!
With that done I did more sorting out of wires and started routing the GIB control stick and the pitch servo wires towards their destination. I once again used some cheap shrink wrap to shroud the pins and wire ends to make routing easier.......I will simply remove the shrink when I get the wires routed to their destinations.
So slowly getting things to where they need to go.
