Bob's RV-8 Build Site
Date:  7-22-2021
Number of Hours:  2.30
Brief Description:  Instrument Ground Block
Fedex came to day and brought a bunch of backordered parts from Vans that I ordered from the FWF and Baffle kits. This time I inventoried the box RIGHT AWAY! Last time when I got the Baffle box inventoried it was a couple months and found I had a baffle part for an O-320 baffle and was missing my #1 cylinder baffling part. So...as monotanus as inventory is....I learned a lesson to do it quickly. I just put in another order for the remainder of the parts I need from the FWF kit thanks to Jim who provided his packing list of the FWF kit I was able to go through it and cherry pick the items I needed.....thanks again Jim!
I then worked in the shop just taking time to cleco the GPS coupling hole doubler in prep for riveting in place (pulled a muscle on my left flank of my back and it was giving me warnings to not get it angry....so I will postpone till the pain subsides)
I was able to work on the grounding forrest of tabs that I am mounting in the avionics area. Long story but I ordered the ground wire pigtails just a hair too short. This may be a better way anyhow. I probably don't need all the tabs on this but it fits well for the mounting location and I will have plenty of tabs. I was able to get it positoined and holes drilled with only a few grumblings from my back. Anyway.....that is the "hash" of work in tonights session.
This session also pushed me past the 2300 hour milestone in the project.......
Cleco doubler
Cleco doubler
Installing instrument panel grounding block
