I installed the cable. Involved routing and using other cables to support. I routed it with a big loop in order to keep it from binding from tight bends.
Recall in the previous log I mentioned that I have to make the cable enter from the right in order to have the closed position when the cable knob is pushed in. I made three cuts on the cable in order to keep from cutting it too short and ruining the cable.
Installed the attachment bolt and the cable stop and after testing it moved smooth and easy. The cable stop was set and worked great to alleviate any strain on the control arm for the door.
