Brief Description: Heater box control cable routing
Well.....I sure spent a lot of time to figure out where I wanted to place the heater cable knob. I will also be putting the Alternate Air knob in the left gear tower so I am trying to place them where there are no brake and vent lines in the way, and also keep the cables from blocking the access holes on the gear tower side as much as possible in case I have to get in the gear tower in the future.
So I finally selected the location and was commited when I drilled the location. Since the cable has good flexibility I chose a place in the front portion of the gear tower pass thru in a place that would allow it to utilize the parking brake cable to tie to and support the heater cable for the loop I will have in routing the cable.
So it was a lot of thinking and a little bit of work for this session.
