Bob's RV-8 Build Site
Date:  3-17-2021
Number of Hours:  2.90
Brief Description:  Firewall Pass-thru
Tonight I tackled the Electrical Bay pass-thru. Stainless steel is kind of a pain to work with and it bit me a little once again tonight.
In my last log I had made a nice template to drill the hole pattern for the pass-thru. With the template located in place I drilled the center hole first and clecoed. I then began drilling the other holes and clecoed as I went. All this had to be done with my angle drill down at the bottom of the Electrical Bay. Room and visibility were limited which is why I used the template.
The problem is that using .032 aluminum for the template was a bad choice. I like to use mild steel as templates when I can because they are more solid but had none available to use. Well while drilling I didn't notice that the drill was actually walking just slightly ultimately resulting in three of the #40 holes to be off location by a little less than 1/16 of an inch. So I grabbed the Dremmel and using a small carbide burr I worked the holes back into location after marking the area to remove material to get the locations back in place. It worked well but took some time.
I then drilled out the large center hole with a 1.125 inch carbide hole saw I bought online. It really worked great and made a nice hole. Next I opened up the corner attachment holes.
Finally I deburred everything which with stainless is another pain but after working it for a while it was done. I screwed the pass-thru and the cover together and belt sanded a radius on the corners. Temp installed while waiting to get some attachment hardware in from ACS.
Holes drilled with template
Radius corners of parts
Temp installed pass-thru
