Bob's RV-8 Build Site
Date:  3-8-2021
Number of Hours:  0.70
Brief Description:  Power Outlet/USB wiring
I worked in the shop last night on the pass thru's for quite a bit. Then came in to put a little time on the project.
I used solder sleeves for the first time because I am daisy chaining the power outlet to the USB power receptacle. They really worked good once I got the stripping length down pat. I used them on the power and ground wires. Short session but a little more accomplished!
Power done with solder sleeve
Both wires done with fast-ons
