Bob's RV-8 Build Site
Date:  3-7-2021
Brief Description:  Power outlet and USB wiring
I took a break from the Pass Thru's and worked on the wiring for the rear power outlet and the USB power outlets. I got the power and ground routed. I am going to pigtail the USBs to the power outlet. I am going to use a solder sleeve to do this as that is what they are designed to do. I made the labels for the wires on both ends.
I wanted to add a snap bushing for the LEMO wires routing since I decided to place the LEMO in the upper portion of the GIB bulkhead. I did that in order to keep it away from the hand area. I am probably going to run a clip or two below the cockpit rail to hold the headset wire out of the way for the GIB.
Ground routed to firewall
Power routed to fuse block
Snap bushing for LEMO wires
