I began to set up to measure the Pitch Servo harness run by clecoing the servo in place.
Using my measuring rope I ran the routing around the servo to keep it clear of the moving parts to the places I will secure the wire. I have conduit that I ran years ago that will be used to run the wire within....with that it was just a matter of measuring with the tape measure.
Pitch servo wire is 11' 5" with no extra.
After that I took a little time to measure from the pitch servo to the Ray Allen pitch servo....I still have to do a little more work on that but it is easier because it is NOT a D-sub connector but a pigtail.
