Decided to work on the Fuse Bay Bus Feeds tonight. I gathered all the tools and climbed into the fuselage to get the work done.
I wanted to leave some extra wire for "in case' I needed it in the future so I tried several routing paths for the wires. I finally settled on running the wire down the gear tower and placing another small nylon tie to secure it. I slid the labels on the wires prior to putting the terminals on the ends...its a small detail that if you forget once...you probably won't forget again. I got the terminals installed and spent some time making sure the wire would not be jammed and chafing on anything.
One thing I learned working with aircraft quality tefzel wire....it is not very flexible (like that used in cars) but even the smaller diameters are very stiff. By the time I finished with the fuse bay bus wires another three plus hours passed!
