I reinsepcted the stiffeners that I riveted last night at the end of the session to double check them since I quit quickly after completing the riveting.
While working on the right console area I noticed I missed two holes on the right spar cap so I match drilled those holes.
My swivel for my airhose on the air drill was starting to leak air pretty bad so I took it apart and looked to see if I could see what the problem was. I found the O-ring to be excessively worn. I found something close in my Harbor Freight set and replaced it. It seems to be working good.....for now!
