I located the drawing that showed where the holes on the fuselage should be drilled for the wiring for the wings to pass through. I did some measuring and the location on the print didn't look optimal.
I contacted my friend Jim and asked him about his as he already completed this part. He also felt the need to move the location and shared the info with me....thanks Jim.
I measured the wing wiring and then determined where the location would be best. I drilled and inserted the snap bushings.
