Once again working on wire routing. I needed to route the bus wires for the fuse bay. I will bundle the six bus wires along the battery tie down, but as they make their way to the back of the electircal bay I will split off the circuit breaker bus feeds from the fuse bay bus feeds.
I decided to drill and install a couple small grommets to pass through the right gear tower and into the fuse bay which is right behind the gear tower. This will take care of the three bus feeds for the fuse bay including the "hot" battery feed which has a bank of four fuses. Rght now I am only using one fuse which will be for the chron/G-meter.
As is the case many times it takes more pondering than time for doing the actual work. Oh well such is the E/AB adventure.
