I continued on working on the bus wire routing tie down bracket on the outboard side of the battery tray. I got the holes for the adel clamps done. I was planning on using my little tie clips as I did on the other panel for the ground wires.....but the clearance between the bracket and the battery though adequate, was not optimal. I decided instead to put Adel clamps.
I cut a short piece of the feed wires that will make up the six busses for my electrical system and found the adel clamp that would be best suited for the bundle.
