Bob's RV-8 Build Site
Date:  1-14-2021
Number of Hours:  1.80
Brief Description:  Complete Battery Tray Mod
I continued on working on the bus wire routing tie down bracket on the outboard side of the battery tray. I got the holes for the adel clamps done. I was planning on using my little tie clips as I did on the other panel for the ground wires.....but the clearance between the bracket and the battery though adequate, was not optimal. I decided instead to put Adel clamps.
I cut a short piece of the feed wires that will make up the six busses for my electrical system and found the adel clamp that would be best suited for the bundle.
Batt tray mod for bus wires complete
