I bagan with installing the circuit breakers in the panel with the proper amperage for each item. After getting them installed I took the panel over to the airplane and clecoed the panel in place and checked for clearance of the bus bars etc.
Rather than leaving the bus bar flat where I would attach the bus feed wire, I decided that a 90 degree bend would make a better connection. So after measuring and cutting a piece of bus bar drilled the holes for the attachment screws and the bus wire and bent the bus bar at the end. It helps to have placed the CB holes in very accurately as then the bus bar can be marked and drilled and they fit very nicely.
So I got the first bus bar made tonight....will continue next session.
