Bob's RV-8 Build Site
Date:  12-31-2020
Number of Hours:  2.60
Brief Description:  Fuse Bay Relay Board mount (cont)
I continued with designing and making the mount. The bottom mount was directly on the fuse bay lower bracket. I drilled holes to have access to where the screws would attach the relay board. I completed the bottom mount and started figuring on the mount for the top of the relay board.
I decided that three mounting locations would be adequate for the relay board. I designed the bracket for the rear portion of the relay board. I will get the bracket close but make sure I set the fuse bay brackets back onto the airplane to be sure the top bracket still fits okay prior to riveting the bracket into the fuse bay to make sure there is no change in the bracket when installed in the airplane.
Bottom mount made and clecoes
Design top mount
Design top mount
