Brief Description: Fuse Bay - design and fab relay board mount
I decided to buy a relay board to take care of my flap and trim relays. I was looking for a place ot mount it. As I was perusing the matter I felt that the rear part of the fuse bay may just do the trick. I did some looking and checking of the fitting of the relay board. I ultimately felt that it would work and set about to design and fab a mount.
I had to trim the relay board a little bit at the corners for clearance. I mounted the fuse bay brackets on a piece of scrap aluminum to be able to design and fab the mounts without it being in the airplane.
I measured and began to mark and design the mounting system. Mostly cypherin this session and started cutting a couple pieces.
