I worked on the Fuse Bay that needed to be completed. I had planned to use some nylon sheet that I have to make gap fillers on the ends of the mounting brackets. It would have been too labor intensive to make with a tighter fit. I measured and made the gap fillers for the four corners of the fuse bay. I will install them after the fuse bay brackets after the bay is completed and riveted in.
