I worked a brief session today due to other responsibilities that required attention. I had the #40 hole drilled marking the location of the nutplate I needed to install for the rear throttle quadrant attachment so I prepped the the location by drilling the nutplate holes, countersinking, and finally riveting in the nutplate.
As I finished I began to ponder an issue that I may have with the panels for the flap actuator and left console side panel that attach to the bulkhead behind and in front of the throttle quad panel. I am going to have to ponder that issue and see if it may pose a small problem.....will look at it next session.
