Bob's RV-8 Build Site
Date:  10-22-2020
Number of Hours:  1.70
Brief Description:  Locate clearance for switches in subpanels
I worked on laying out more switches. I started with moving the boost pump switch and light a little higher and changing the border for visibility without the cross stripes.
I then began to look on placing the rheostat pots on the subpanel. I felt with the rheostats and the two toggle switches it was just a little too cramped. The pots are kind of big and i want to make the subpanels removable with all the switches attached. So I felt if I would cut a little clearance into the bottom of the subpanel area that I would gain adequate spacing. I measured and cut a template out of poster board to outline where I wanted to put the clearance for the pots. I marked the areas to cut out for the pots and was satisfied with where they would be.
I am going to lay out all the panels that need to have switch, light and other holes in them and then get them all cut at the same time.
Different marking
Different marking
Clearance for rheostat pots
