Last session pushed me over the 1900 HOUR mark......and still moving on in hopes to get this project completed prior to the turn of the century!
Anyway, I continued on the GTX 45 brackets for the tray to be held in place. I got the forward angles drilled and nutplates installed and then match drilled to the airframe.
I then began to design the right hand rear bracket for that corner. I decided to only use one #8 screw to secure that support. I drilled and installed the nutplate then drilled the holes into the airframe and match drilled them to the support.
One more bracket to go for the left rear portion of the tray.
