Brief Description: Prototype Panel - continue cutting left side
I got back in the shop and continued programming and machining the cutouts on the left side of the panel.
I cut the opening for the GMC 507 yesterday and today I will get the cutouts for the Flight Data Chronometer-G meter-Clock as well as the GDU 460 PDF 10" display.
Once again it takes a little time to make the program and I am using a couple new functions that I am trying out for programming....so there is a bit of time baked into the process in writing the program. The good part is that if all the cutouts prove to be adequate then I have the program ready and if I have to tweak the location a bit that will only be a minor change to the start point and I won't have to change the cutout profile....so the "real" panel should take less time.
All I have to do now is the indicator lights and switch holes.
