Bob's RV-8 Build Site
Date:  7-7-2020
Number of Hours:  1.70
Brief Description:  Forward Baggage Cover Panel #2
I started by transferring the holes along the front part of the baggage area that would also hold down the panel. I have made some poor mans transfer screws by grinding off the heads of some #8 screws by putting them in my drill and running them against my belt sander to form a point. I insert them into the nutplate and set the panel back down in place then give a tap with the hammer over the transfer screw and I have a nice center punch mark to locate the drilll location on the panel. It has worked really well.
Next I measured the location of where I wanted to drill the support bracket on the back wall area and set the panel on, marked the location and match drilled the panel and bracket in place.
I removed the bracket and drilled and riveted the nutplate onto the bracket.
This session pushed me over the 1700 hour mark in the build!!
Poor mans transfer screw
Support bracket
Support bracket
Support bracket drilled
