Bob's RV-8 Build Site
Date:  2-8-2020
Number of Hours:  5.80
Brief Description:  Fairings joined and Horizontal stab
I started by sanding the micro off the horizontal stab on the fiberglass endcaps. I put the end caps on and micro about 2 years ago....I figured it was a good time to start working them. It all went pretty good. They have a few low spots and I will micro again to get them finished up.
While I was working on them Rob texted me and offered to come over and help! Once again with Robs experience as I have stated previously, is worth having for doing any part of the build. He came and I left the HS caps for later and we went and worked to join the fairings together. He felt as did I that the fairings were at the point of doing the joining of the rear halves.
Rob cut the fiberglass cloth as I did some prep on the halves of the skirts. We did 3 layers using the plastic sheet method that he taught me and got them wetted up, laid down the layers and clecoed in place. When they cure I will remove the fairings and lay some fglass on the inside of the fairings.
After Rob left I went back into the shop and continued to work the tips on the horizontal stabilizer.
HS Fairing Caps
HS Fairing Caps
Rob prepping Fglass cloth
Fairings joined with fglass  on skirt exterior
