Bob's RV-8 Build Site
Date:  10-6-2019
Brief Description:  Canopy Slide Block #2
I got the new slide block in on Saturday. I was surprised at the speed Vans shipped it. I was glad to I could continue the canopy frame fitting process. I was able to compute the location of the new hole based on the first one.....it worked out great and the clearance was right in specs.
I began to work on the anchor block that receives the anchor pin that is welded to the frame. Will finish it in next session...that's all for tonight.
Slide block #2
Slide block #2
Correct clearance
Correct clearance
Ready for more canopy tweaking
