Bob's RV-8 Build Site
Date:  10-2-2019
Number of Hours:  1.00
Brief Description:  Canopy Slide Block #1
I worked on the canopy slide block. This step kind of leaves it up to you (spell that trial & error). I measured as best as I could and came up with a dimension that I felt would work to drill the block.
I drilled and counterbored it and the anchor pin was just clear of the canopy slide rail in the back and began to touch the rail about half way travel towards the front.
So I did what if have done many times before......ordered TWO more blocks....just in case! I also decided to get another anchor block also....just easier so I don't have to order just one....with shipping. When everything comes from the opposite coast shipping adds up.
