Bob's RV-8 Build Site
Date:  9-6-2019
Number of Hours:  1.90
Brief Description:  Canopy Rail and Spacer (cont)
I removed the rail spacer from the fuse and milled off about 1/8 th inch from the rear end of the spacer because it stuck out slightly beyond the cap.
Next I countersunk all the holes in the spacer and the cap for the rivets. I also placed the canopy slide rail back on the fuse and drilled the most forward hole through the rail cap and rail spacer.
Rail cap countersunk
Locate and drill forward hole
