Paint has cured overnight. This session was only pulling tape off the interior. As I said before, it came out ok for an novice. The little "tape dots" I made using a 9/16 hole punch from some cheap tool store. The little tape dots stayed on the bolt heads great and kept them from being painted.
Time to remove tape
Sure is quicker to remove tape than install it!
My little "tape dots" I punched out worked well on bolts
