Bob's RV-8 Build Site
Date:  7-2-2018
Number of Hours:  1.00
Brief Description:  Windscreen frame fitting #2
I did more checking of the canopy windscreen fit and positioning. Overall it is pretty good but the flange that bolts to the longeron was bent up slightly. I used a small vise with aluminum angle on the jaws to protect the weldment while tweaking the flanges. After a little adjustment the fit is good to go so I removed the frame and began clearing everything out of the fuse. Next step will be cleaning the fuse in preparation for painting.
Checking fit and squareness
Done...back in the waiting room
