Bob's RV-8 Build Site
Date:  5-11-2018
Number of Hours:  1.00
Brief Description:  Landing Gear Installation - Drilling
I took some time to basically get everything positioned and marked prior to drilling the holes for the gear brackets. I had to cut a little notch for getting the outboard brackets in place. I also took the opportunity to cut clearance for the rear bolt position.
Fitting brackets
Fitting brackets
I had to notch out the skin to get the bracket in the bay
Positioning the wear bracket and making clearance for bolt
