Bob's RV-8 Build Site
Date:  11-11-2017
Number of Hours:  1.70
Brief Description:  Manual Trim
I began by fabricating the trim slide tube that slides in the assembly to input adjustments to the trim system. Next I made the connector plate that is located between the trim cable and the slide tube.
I completed the work session by drilling the cable anchor holes for the rudder attachments.
Slide tube
Slide tube
Connector Plate
Connector Plate
Rudder cable anchor
Rudder cable anchor
