Tonight I machined the rear mount angle to fit the milled out portion of the tubing. This will hold down the rear portion of the mounting tube and will bolt to two of the bolts used in the right gear tower. I also machined off some of the angle to clear the rivet heads on the bottom of the gear tower angle. So far so good.....
