I did some more fitting and relieving of the back edge of the stops to extend past the skin of the tail so the stops would make contact properly. After some tweaking I was happy with the stops so I drilled and counter sunk the holes. Then I spent time deburring and finishing the stops. I decided to use a small champhering cutter to put an angle on the stops....for asthetics and cutting down drag adding .0000000000001425877468 more knots to my airspeed LOL
