Bob's RV-8 Build Site
Date:  3-27-2017
Number of Hours:  1.40
Brief Description:  Control Column
Spent some time fitting the brass bushings on the control column. Kind of a tedious task getting
the angle of the control column and with marking and using the belt sander I was able to get them in the ball park...but they need more work. I also ground down the pivot bushings on the front
and back control sticks to get minimum spacing between control column and the control sticks.
Things are roughed in now and will do some more work on the bushings on the next session.
Fitting the bushings
