In the process of riveting E610 & 611 PP I messed up 4 rivets! Too much time away from the rivet gun I guess. Anway I drilled out the mutated rivets and replaced them......job well done!
Rivet E-709 to E-702. Rivet E-703/704 assembly to E-702......messed up two more rivets! Removed and repaired bad rivets.
Riveted WD605-R-1 to E-709/702. CAME OUT BEAUTIFUL!!!! Nothing out of the ordinary...just riveting and re-riveting. I find that other than doing major blunders (like when I was backriveting and had the rudder off the backrivet plate....that was unfixable!) most of the small stuff like bad rivets etc are simple fixes.
