Steve & Nancy Riffe
Date:  6-13-2014
Number of Hours:  1.00
Brief Description:  Recieved Avionics!
UPS guy showed up today with a box from Stein Air. Whoo-hoo! I received a Garmin GTN650 and GMA240, along with a custom made wiring harness. I had previously purchased an ICOM A210 backup radio, which I had Stein incorporate into the wiring harness—looks real good. After checking everything over, I removed the instrument panel and pulled off some of the blue plastic on the side that I’m about to cut for the radios. I have a pretty good idea of where to cut, but think I will measure it at least a few dozen more times—I’d prefer to get the cut right on the first attempt, cause a second attempt would have to be on a new panel.
Radios, audio panel, wiring harness
Radio stack
Radio stack
Measuring for cut at top of panel
