I installed both left and right inboard and outboard wear plates with the specified hardwear. I then torqued all 8 bolts to 65 inch pounds and marked with orange torque seal. Although the manual doesn’t say when to install the wear plates, it is usually assumed they will be installed during final gear attachment. However, I chose to install them now while I have good access.
