This AM I cleaned all of the sanded areas. I mixed up a slurry of micro and applied to the rivet lines on the left skirt and the diagonal down tube on the right skirt . Tonight I sanded all of the micro with 80 grit to get the heavy areas cut down, then sanded with 150 grit. Feels good—so I cleaned with MEK then shot a coat of sanding primer.
