Brief Description: Sanded skirts, applied resin to left side
Early this morning, I scuffed up all of the CS4-4 rivet heads and cleaned with MEKāthen mixed up some micro/flox which I applied over all the rivet heads. Tonight the slurry had dried, so I sanded the left skirt once again. Then gave the right skirt a very heavy sanding. Cleaned up the skirts with MEK and mixed up some resin with a small amount of micro. I spread this on the left skirt using a credit card. I had enough goop mixed up, but before I could start on the right skirt, it got hot and way to thick to spread, so I called it a night.
