Steve & Nancy Riffe
Date: 8-3-2013
Number of Hours: 3.00
Brief Description: Liquid shim-aft skirts 3
Well, it just is never quite good enough to call it done. So, I sanded the aft area and clecoed the skirts back to the frame. I discovered it didn’t fit quite as well as before I added the filler micro. Removed and heavily sanded the new micro. Added the skirts back, removed, sanded more etc. After about 4 of the add, remove, sand sessions, finally got it to fit much better. Still had a slight gap on both sides for about 5” on either side of the slide rail. I laid down some packing tape and mixed up some micro. Applied to the areas with the gaps and shut the canopy. I also wet a single layer of glass which I added across the back end that humps over the slide rail. Later, after everything had set up, I removed the canopy, trimmed off the excess micro and sanded both sides. I mixed up another batch of micro to smooth the edges on the bottom of the skirts and coated the outside very aft end.
Added more liquid shim, add glass to top
Shim after removing skirts
Lathered up the newly added glass area
