Brief Description: Liquid shim added to aft skirts
I need to close up the aft end around the slide. I used some modeling clay to form a kind of dam to keep resin/flox from moving forward. I used wax paper to cover the aft deck area as well as some clay forced into the grooves of the slide. Mixed up a thick batch of resin/flox with a small amount of micro. I gooped this onto the area on the rear deck and also coated the underside of the aft skirt. Nancy helped me get the skirt clecoed to the frame and then we shut the canopy. Tomorrow we’ll check to see if we have permanently attached the canopy or if the clay & wax paper performed as we intended.—1 hr.
