Brief Description: Added glass to aft skirt-underside
Short night in the shop. Nancy helped me remove the skirts which are joined together on the top side only by several layers of glass. We flipped the skirts upside down on the workbench. I sanded the underside with 80 grit to ruff it up a bit and then cleaned with MEK. Cut two pieces of glass which I wet out with resin. Applied the layers and added peel ply—left it to cure overnight.
