I had a few items that needed a little work on the canopy frame. The slide block on the rear of the canopy frame was contacting the fuselage skin just slightly, so I removed the block and ran the bottom against my band sander. Reinstalled and checked fit—works much better. Also, I had not drilled the canopy frame to the roller assembly. I wedged a block between the frame and side rail, then progressively drilled the assembly up to a #11. Removed, deburred and installed the screws. I added some “feet” with castors to the false spar and removed the fuse from the rotisserie—then moved the fuse out of the shop. Vacuumed out the shop-turned the fuse and moved it back in tail first.
Wedged frame in order to drill frame to roller assy.
