After sanding the front end of the skirts a bit more, I marked the F821 forward top skin where it meets the skirts for hopefully one final trim. The top hole in the F8104 support rib had not yet been drilled, therefore, before removing the skin, I match drilled the F821 skin to the rib. Removed the skin and clamped the edge to the workbench. Filed to the line previously marked, cleaned up with 400 grit sandpaper. Deburred the match drilled holes and used the pneumatic squeezer to dimple the holes. Felt really good to get away from plexiglass and fiberglass for an evening—sorta miss working with aluminum.
