SIKA-another evening of the same. Cleaner, primer,glue. Made a cosmetic glue pass on the inside of the front bow, smoothed with a wet finger and pulled the tape from the frame and the canopy. Repeat for the left side, repeat for the right side. Done with the glue! At least canopy to frame glue. Pretty happy with the way it turned out—not perfect, but I can certainly fly with it. After it sets for 24 hours or so, I’ll remove all of the tape I had in place to protect from unwanted primer drips and glue. Some of the exposed frame needs a bit of clean up as well. Glad to be done with the glue, but now time for the dreaded pink skirts!
