Finished trimming the sides of the canopy to just below the tube of the frame. After trimming, I sanded the edges—again. I cleaned up the outside as best I could and trimmed the outside vinyl back about ½”. I ran a strip of black electrical tape around the outside of the canopy, followed by a strip of painters tape. I left approx. 1/8” gap between the tape and the edge of the canopy for final sanding and polishing. Added the 6 clecos back to secure the canopy to the frame—found a slight issue with this process. Before I ran the tape, it was easy to see the hole in the frame thru the plexi, but now it is a process of a “hunt for it”. I believe I’ll cut a small area in the tape around each cleco. After the Sika primer is applied, I won’t have time to be fumbling around trying to cleco the canopy into position.
