Made another 3/8” cut tonight. Really thought it would be the last—but I need one more. The canopy to roll bar has gotten to about a popsicle stick width now. I also made a few relief cuts where the canopy is contacting the down tubes of the frame--used a sanding drum on the dremel. These cuts allow the canopy to pull in just a bit. Most likely everything will shift once the windscreen is separated. Made up a cardboard template to sandwich between the front bow of the frame and the roll bar in anticipation of making the separation. Need to finish moving the canopy around soon—my helper is growing weary of my request for help when she is busy with her own projects.
Closing the gap
Relief cut-sanded smooth-pic seeing ragged edge of vinyl
