Steve & Nancy Riffe
Date:  10-15-2016
Number of Hours:  0.50
Manual Reference:  8-71
Brief Description:  Baggage Door Hinge-Rivet
---I finished up squeezing the remaining rivets that attach the baggage door hinge to the forward top skin. I did it all with the pneumatic squeezer. In order to be able to remove the hinge pin, I filed the forward eyelet at a 45 degree angle and filed a small groove in the top skin. This is just enough to get the pin inserted and removed. Once the pin is in, I can rotate the leg under the edge of the skin which the baggage door seals against. There is no way the pin can come out when the door is closed.
Hinge riveted to top skin
Another pic of hinge rivets
Hinge Pin removal
Hinge Pin removal
