Steve & Nancy Riffe
Date:  8-6-2015
Number of Hours:  1.00
Brief Description:  Baggage door-rivet inside skin/ribs
Second session for the day. I figured the proseal I had applied on the baggage rib/inside skin should be cured by now, so I removed the straps holding it down. I removed a cleco on each side in the middle of the rib—nothing sprung apart—good! I ran a #30 reamer thru the holes to clean out any proseal, then dipped an LP4-3 rivet in primer and pop riveted it in. I proceeded with this process until all holes were filled with rivets. Next, I pop riveted the hinge to the top rib with CS4-4 pop rivets. I set the door back in place—fits pretty good all around except on the forward edge near the hinge area—sits a little proud, but I can push it down where it’s flush. May need some additional work here, just not sure what. I was most concerned with the area along the bottom of the door near the lock, but it fits quite well.
Pop riveting skin to ribs
All pop rivets installed
Door in place--awl is area that needs some work
